Tried to advance the ignition timing per the Haynes manual. Ran into a bunch of problems. Car is a '90 EFI 5-speed.
Haynes sez to ground the STI terminal to the engine with a jumper wire. I think this is a white female connector (insert crude joke here) near the power brake booster. I did so and the car will not start. Undo the ground, car starts. Put ground back in, car stalls. So that didn't work.
Located the timing marks on the block, by the pulley. Could not find any mark on the pulley itself for the timing light to see, to check timing. Plus if it's necessary to have that ground thing in, maybe I wouldn't get a good reading anyway.
The disty rotates counterclockwise, according to Haynes. Therefore advancing the timing would consist of rotating the disty cap clockwise, correct? I had VERY little adjustment left to rotate it clockwise, so I moved it all the way over. I am advancing the timing to see if this improves fuel mileage. And I am using 93 octane to prevent detonation with advanced timing.
Any thoughts, suggestions, rude comments about my intelligence, etc.
