Runs on Starter fluid, Not Gas?
    On two of my festivas when I first bought them, they had been sitting for a while and would not start up. They did run with the starting fluid, so I figured out it was the injectors. I took the injectors out, and sent them off to WitchHunter performance. They service the injectors, and when you get them back, they look and run like new. They also give you a test report. http://www.witchhunter.com/ It's only $19 per injector and they do an awesome job. When I got my report back, it said that one of my injectors was stuck closed. I installed the injectors and it solved the problem.
    90 Festiva with Brand new B3, 5spd
    92 B6 Festiva, 5spd
