i have a 1989 ford festiva and the ball joint is shot but i have another part festiva that i can take the arm off of but i can only un bolt a little bit and then wont go any farther(on both in same spot) and was wondering how they come off
Lower Control Arm on 89 Festiva
Which end are you talking about? Upper end, or down by the pinch bolt?
1989 L - 247K miles Slick
Is your car rusty? If so then the hidden nut is the problem. Spray them thru the access holes with a penetrating oil. Then work back and forth till they free up. It is VERY easy to break them off. I've done that a few times.
