So the consequence of neglection results in some much needed repairs.
I have been busy this past semester with my prelaw program which is the reason for my excuse. I need a minial of a 3.6/8 for the next two years to be consideredto law school and have been daily driving for over 5,000 miles (no tune up). Yes idiotic but the pressure got to me.
Now the oil is slowly leaking from the oil pan and head gasket. To top that off the oil pan bolt is rounded as well as 2 head bolts.
The point is that I have little money and its my DD so major repairs such as full gasket replacement is out of the question for at least the semester.
This is my plan (please give advise or tips on any of the following)
* I know more is needed but time constraits and no $*
1. Clean entire engine with simple green/similar product (makes work a bit easier to me)
2. Bolt tap/extracter for the 3 bolts
3. oil pan/bolt/gasket( suggestions? brands? rockauto?) and oil
4. head gasket, razor, high temp brake fluid (again suggestions,brans,rockauto?()
Once I get the leakage out of the way then basic tune up
5. trans flush, air and oil filter, spark plugs, disty cap and rotor.
6. oxy sensor
It seems simple but chances are its gonna take weeks.
I know I am behind 5,000 miles but hopefully nothing else is wrong because the engine, trans, and brakes are strong. Its just the slow leak for now
6. oxy sensor
