I think I would still try to replace the rounded Oil pan bolt though.
Neglection of Festiva Repairs
- Unknown
- Quentin Crisp
- Bumper Sticker
Update:
Cleaned engine bay with simple green. Dang the silver is showing (didnt know it could get that clean)
So gonna drive for a few days and see exactly where it is coming from. Someone suggested that it could be the valve gasket (above sparks plugs) and is just dripping down.
*If the gasket is the case then what would I need to take off? (carb model)
Just look at the motor; it will be obvious what needs to come off. It's not very difficult. This is a pretty easy project so just dive in and do it, and you'll get confidence to tackle more things.Originally posted by collegeboi View PostUpdate:
If some issue comes up in any project, someone here will know how to help you.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
UPdate pictures
So Its either crank seal or valve cover, Im hoping valve but by the pictures, imma have to drop the motor
The more I look at this, it doesn't look like leaking from the valve cover; that would just seep down the engine and get it dirty. This looks more like someone left the oil filler cap off while the motor was running.
Others have any thoughts as to what else it could be, or agree with me?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Crank seal is leaking and the timing belt in flinging the oil. Your VC is probably leaking too. Dont try changing the oil pan gasket. You dont have to drop the motor. Where is your timing belt cover ? That keeps dust and dirt out of the crank seal. Thats my 2 cents. Keep drying stuff off and checking it. You will find where its coming from.sigpic
I'm pretty sure that is your camshaft seal. While you're at it, you should change the timing belt, timing belt tensioner, water pump, and crankshaft seal.
This is how my engine looked before I replaced all the above mentioned parts. Now it's dry as a bone.
1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
Oil is probably coming out of valve cover....air coming through the grill carries it to the firewall passenger engine mount area. But yes your front crank and cam seals probably need to be changed also. All that can be done on a weekend. It's not like you go to school 7 days a week.---------------------------------------------------
Yeah, but he was asking what to take off to do the valve cover gasket. Doing the seals might be a little out of his league without supervision/assistance.Originally posted by festivaWES View PostOil is probably coming out of valve cover....air coming through the grill carries it to the firewall passenger engine mount area. But yes your front crank and cam seals probably need to be changed also. All that can be done on a weekend. It's not like you go to school 7 days a week.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I don't think it takes a rocket scientist to change a valve cover gasket. You would have to remove the intake and the bolts securing the valve cover to the cylinder head. At this time it might be a good idea to change those rubber/plastic gomets that are under each valve cover bolt.Last edited by festivaWES; 09-11-2009, 08:21 PM.---------------------------------------------------
Right, I think he could do that much, it's the seals that are more involved.Originally posted by festivaWES View PostI don't think it takes a rocket scientist to change a valve cover gasket. You would have to remove the intake and the bolts securing the valve cover to the cylinder head. At this time it might be a good idea to change those rubber/plastic gomets that are under each valve cover bolt.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
