do i need a strut compressor? i have never done this and has been told it is easy.And any hints beside pb blaster the bolts? BTW i am using FMS lowing springs and KYB GR2's.
installing fronst struts
Yes you will need a spring compressor, it is easy. All I did was soaked the bolts with PB blaster a for a few days before changing them, then hit them with an impact and they came off with no problems.-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
ok about how lond did it take you?1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1978 25th Anniversary edition Corvette
1983 Chevy Elcamino
1993 Ford Festiva GL
2003 Hyundia Santa Fe ( Wifes Daily driver)
some old dodge motorhome I have no idea of the year
Originally posted by marinepolice03 View Postok about how lond did it take you?
When I did mine, I jacked around for a stupid amount of time trying to do it without spring compressors, finally broke down, went into town, bought a set of compressors, and had both sides done in less than an hour. And maybe I just got lucky, but I didn't really have any problem with nuts and bolts rust welded. Just my experience, tho.
1989 L - 247K miles Slick
I take them off all the time without a spring compressor. Putting them on is a different story!!!---------------------------------------------------
compressor for the fronts...not needed in the rear."FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by GenevaDirt View Postcompressor for the fronts...not needed in the rear.
thanks guys pretty shure i can do it tommarrow. if been soaking the rear bolts for the past day.1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1983 Chevy Elcamino
Putting on the front FMS lowering springs, maybe he won't need to compress the new springs? Your thoughts please.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
they are slightly used i forgot to say1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1983 Chevy Elcamino
thanks i am getting ready to start doing them1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
1983 Chevy Elcamino
