Driveaxle seal replacement (manual 5-speed)
  • Driveaxle seal replacement (manual 5-speed)
    Yesterday, I replaced (uneventfully) both driveaxles on my newly-acquired (for $100 with absolutely no rust) 1991 Festy. I put about 2.6 quarts of ATF in to get the proper level.
    Much to my surprise, when I returned from my short test drive (after dark), I found a large puddle of red ATF in the driveway (and nowhere else). It's like it all leaked out in the first 2 feet of travel.
    Interestingly, when I drained the transaxle in preparation for replacing the driveaxles, I got only a small amount of (brown) fluid out. I'm now suspecting that the driveaxle seals were already blown when I got the car. Alternatively, maybe the fluid was very low, the seals had dried out as a result (the car hadn't been driven for several years when I bought it), and I damaged them inserting the new driveaxles. The odometer reads just over 100K but the speedo cable is snapped, so actual mileage is unknown. It looks like a 100K car (spotless interior, etc.).
    The Haines manual says that replacing the seals is a simple task. I don't have a lift, and am not comfortable going that far under the car on stands, particularly on my sloping driveway.
    Does anybody know:
    (1) Are the proper seals available? Part number(s)? All we have really here in Anchorage is Napa and Schucks.
    (2) If I take it to a lift-equipped shop (close by, so I don't burn up the transaxle), what should I expect to pay in labor to replace the seals on both sides? Everything came apart very easily when I did the driveaxle replacement. Should I even risk driving the car with what may be no transaxle fluid.
    When I get some daylight after work today, I'm going to have a look-see to try to confirm that it leaked out the driveaxle seals and not somewhere else (like a crack in the transaxle case or seal between the two halves of the case).
    Thanks.
    88L black, dailydriver
    88LX silver a/c, dailydriver
    4 88/89 disassembled
    91L green
    91GL aqua pwrsteer
    92GL red a/c reardmg
    1952 Cessna170B floatplane
    They are very easy to put in. But you have to take the axles back out. And buy more fluid or catch and reuse your fluid.
    -Greg
    Redneck Engineer
    FOTY - '09
      you should be able to get the seals new at Napa. can't recall P/N's, but something like 2007N and another, depends on brand.
      as far as labor, call up the shop and see what they charge hourly rate.
      -Aspire brake swap COMPLETE!
