What size tires ?
  • What size tires ?
    anybody know what is the largest tire i can fit on a 13 inch rim for my stock non aspire swap 88 festiva ?
    largest as in width or aspect ratio?? how wide is the 13" rim??
      tires ?
      all i know its a geo metro. will that help ? thanks
        max is probably a 175/70/13 or a 185/60/13
          That's what I was gonna say too. I've seen 185/70x13 on the 4.5" wide Metro wheels. Personally I'd put the 175s tho. Probably the only thing you'll find in a 60 series tire is the Sumitomo 200 HTR, which is high-performance summer, not good for all-season use.
            on a 6" rim you COULD fit some 205/60's....They would look like putting some 175/50's on festiva stock rims.
              metro wheels.
              well i got the four wheels for my 88 festiva. took them to the tire guy who said 160/70/13 will fit. i measured the width it came out to approx,5 3/4, . what do you think could i go with another size ?if so what size ? thanks guys.
                ^ the wheel width is measured inside the outer edges. Measure where the tire beads will sit.
                Oscar
                  Yeah 160/70/13......that size is available!?! Your not going to measure from outside edge to outside edge to get rim width.
                  I believe metro rims are the same width as festiva's 4.5"
                  175/70/13 tires..they are available and cheap.
                    You would be amazed how common that is. Most people just measure the total width.
                    Oscar
                      That's what size I have on my festy, $45 a piece.
                      -93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
                      -85' Nissan Sentra 5 spd.
                        tires
                        imgoing for the 175/70/13
                          I personally would try to find a shorter sidewall for better handling but the 175/70 is a good all around tire for us. Shorter sidewall than a 155/80 at least.
                          175/70/13 is 7.2% taller than 145r12, just fyi.
                          91GL BP/F3A with boost
