Need help in Missouri with repairs
Originally posted by Pu241 View PostJust south west of St Louis!
Yahoo Maps is your friend!
http://maps.yahoo.com/#mvt=m&lat=38....0MO%2C%2063051
Im barely functioning with my computer now. Im about to unplug it all. Im fully aware of Yahoo maps, map quest and such. Thanks for your usual...eh nevermind.sigpic
Come on spit it out, I never let something like that fester!Originally posted by freshtiva View PostThanks for your usual...eh nevermind.
How was I to know your computational processor is having issues?
Just thought you were getting lazy in your old age.
Does it need a good cleaning out (virus, malware, etc) or corrupted/missing files, which calls for a repair or more likely a wipe and reload of the OS.
Also, might just want to get a new drive and do a fresh (no pun intended, that whats it's called) install. Then set the current drive as a slave and transfer over what you want from the old drive to the new drive. Then wipe it throughly and use it as a backup.
Just a though, no malice intended!'93 Blue 5spd 230K(down for clutch and overall maintanence)
More bad news. So now that the thermostat is replaced, there's pressure on the system and now the head is leaking right underneath the temp gauge sensor see pic. So like I said in the original post if anyone could help me that would be great. If I have to repair the head and my (JB WELD trick don't work)then Im just going to replace everything. But what I would like is a list of seals and gaskets I need to buy. I plan on replacing the H2O pump, timing belt for sure, but I know there are alot of seals. So any help would be great. Thanks Mark[IMG]
[/IMG]
Lifes to short to sweet the small stuff. Enjoy everyday like it was the last.:p
UPDATE: So the head is not cracked, it was a hose that was loose that goes from this pipe thing to the block. I don't know what it is or what it does but nothing a hose clamp couldn't fix. WOW I was in panic mode, what a relief!!!Lifes to short to sweet the small stuff. Enjoy everyday like it was the last.:p
Adware, for Virus protection no lessOriginally posted by Pu241 View PostCome on spit it out, I never let something like that fester!
. Finally got it out after a couple of days work. Did a file search and deleted part of it. Then the rest of it disappeared. Im back up to half speed now.
Excellent! Good to hear.Originally posted by taytay91 View PostUPDATE: So the head is not cracked, it was a hose that was loose that goes from this pipe thing to the block. I don't know what it is or what it does but nothing a hose clamp couldn't fix. WOW I was in panic mode, what a relief!!!90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
