Does anyone know how to remove the frame for the factory Ford sunroof? I have the glass out, and the four screws I found--1 each for the front hinge points and two for the rear latch--but I can't figure out how to remove the frame itself, and don't want to damage it. Anyone have experience with this?
How to remove sunroof frame?
Tags: None
Get ahold of Tony Cash. I'm sure he has removed some, so he may be able to help you out.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
I removed mine not that long ago, you need to remove the headliner and you'll see screws all the way around the frame, take them out and it should separate into two pieces
OK thanks. I'll go look at it. I was under the impression that the headliner is held in by the sunroof frame, but maybe I can work it out. Or something.Originally posted by Damkid View PostI removed mine not that long ago, you need to remove the headliner and you'll see screws all the way around the frame, take them out and it should separate into two pieces90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
The headliner is also held in by the sunroof i still have my sunroof so i can get some pics for ya if you want to show how it comes apart
Thanks all, I got it out with no problems. Once I figured out that you can just pull out the fabric covering the screws, it went pretty easy.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
