I have a water temperature question. What is the normal temperature readings. My gauge reads about little more than half when cruising and a little over the 3/4 when pushing the engine hard. Am I running too hot?
Water temperature question
What's temp of the T-stat?Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
Could be 160, 180, 195, or 205. The 205 would make it run that high, but you're still in the safe area.Originally posted by lancerevo View PostI don't know.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
Probably. Usually it should read a little under the halfway point. Do you know how to check if your radiator is clogged? Basically you put your hand on it in several places, feeling for cold spots and hot spots. If there is a very noticable difference, your rad is clogged.Originally posted by lancerevo View PostI have a water temperature question. What is the normal temperature readings. My gauge reads about little more than half when cruising and a little over the 3/4 when pushing the engine hard. Am I running too hot?
As an emergency measure, put your heater on to lower the engine temp a bit. The heater core is simply another radiator.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
the thermal reisistor in the head is what provides the ground for the gauge (5v reff.) it's not an exact science for these, so there's something like a +/-10% tolerance on them. generaly, as long as your fan kicks on and the needle stays below the red, you're good to go.Trees aren't kind to me...
Answered on your other post.Originally posted by howard66 View PostDo you know where the cooling fan sensor is on my 90 festiva? I always heard half was normal for temp guage.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Also the radiator, and heater hoses....Originally posted by TominMO View PostProbably. Usually it should read a little under the halfway point. Do you know how to check if your radiator is clogged? Basically you put your hand on it in several places, feeling for cold spots and hot spots. If there is a very noticable difference, your rad is clogged.
Good to know you made it home safe, TominMO!!!!Contact me for information about Festiva Madness!
