missfiring
  • missfiring
    ok my gfs moms yellow festiva hasnt had a tun up or oil change in awhile like almost two years so i finaly bought every thing to make it run a little better. so i did the basic tune up and air cleaner new valve cover gasket and tb gasket i didnt do a fuel filter jsut yet but the car was missfiring for a long time so i thought i would have fixed it but it ran good for the first 5 mins then started it again so i was messing with it and number 4 is not firing but when i pull any other wire it sparks all round the bottom of the cap. so what do you guys thing ive got new wires and cap rotor and plugs so they shouldnt be bad.
    Is this the same plug that was not firing before? Remove your cap again, and look at the contact point for the #4 wire. I have had faulty caps before that the contact point was loose or misaligned and the rotor broke the contact off. Let us know what you find.
    My Fleet:
      exactly, i'd replace the cap and wires (new doesn't = good)
        haha yeah il look but im garented that they ok and yes same one as before but il see what i can find out
          You can check the resistance in the spark plug wires with a volt-ohm meter (VOM). If one is too high it is no good.
