I recently replaced both driveshafts in a 91 with perfect body that I picked up for $100. I have yet to drive the car more than in the parking lot.
The passenger side stays in. The driver side, despite seating normally, simply will not stay in. I can drive only a hundred feet, and end up with a puddle of new ATF. When I take a look, the driveshaft is still in the transaxle's spline, but not all the way.
I've tried TWO new driver side driveshafts -- same problem. I even tried bending the little clip thing out to be a little larger diameter -- no luck.
This car will rust here in AK before I ever need to replace the driveshafts again. Is there anything I can do to make it stay in, even permanently?
OR, is there something wrong inside the transaxle? Am I going to need to put in another transaxle? I have several here that I could use, but I've never done this kind of thing and it's starting to get COLD and DARK up here.
Before starting, I drained the transaxle fluild -- only a small amount came out -- this problem, if it is indeed internal damage to the transaxle, may have started before I bought the car.
