tach stoped working
  • tach stoped working
    i swapped my gauge cluster with a lower mileage and cleaner one and the tach. does not work now. im confused i think the car was a 90 L-Plus and i own a 90 L-plus. could it just be the cluster?
    1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
    1978 25th Anniversary edition Corvette
    1983 Chevy Elcamino
    1993 Ford Festiva GL
    2003 Hyundia Santa Fe ( Wifes Daily driver)
    some old dodge motorhome I have no idea of the year
    Was the tach working before in your car? The title suggests that it was working and then it quit. If it never worked in your car, make sure that the black plug (left side) that connects to your gauge cluster has a yellow/green wire. That's the one that brings the signal from the coil.
    Oscar
      yes it was working in my old cluster and this one it does not. i will check the wire in the morning
      1983 Chevy Elcamino
        It could be that the screw that makes contact on the back of the cluster was once removed and never put back in. It may look something like this:
        photo thanks to perucho
        My Fleet:
          Did you get it working? If so, what was the problem?
          My Fleet:
            i got it working. i just manually moved the tach pointer once and then back to 0 and pluged it in and it started working
            1983 Chevy Elcamino
              Great! I'm glad you didn't waste your money on a broken cluster.
              My Fleet:
