i have coolant dripping from my oil pan, it seems to be coming for the rear of the engine. but i can't see exactly where from. are there any coolant hoses or lines on the PS rear of the engine? where should i be looking? thanks for the help in advance.
coolant leak?
Yes....there is where the heater hoses from the heater core hook upOriginally posted by cubstiva1 View Posti have coolant dripping from my oil pan, it seems to be coming for the rear of the engine. but i can't see exactly where from. are there any coolant hoses or lines on the PS rear of the engine? where should i be looking? thanks for the help in advance."FLTG4LIFE" @FINALLEVEL , "PBH"
Closely inspect the little hoses that come off the hard line that runs around the motor. I've seen so many of these bust.....I just did a motor swap last week because of the little hose that goes to the head right by the thermostat.-Greg
Redneck Engineer
FOTY - '09
thermostat would be drivers side front tho, right? i don't see anything in that area. i'm thinking it must be on the passenger side of the motor. i've not had time to really look into it, and i didn't want to start over the weekend when parts stores might be closed.Originally posted by eurotiva View PostClosely inspect the little hoses that come off the hard line that runs around the motor. I've seen so many of these bust.....I just did a motor swap last week because of the little hose that goes to the head right by the thermostat.
I would bet on a heater hose gone bad. Had it happen to me. Mine was a quick fix though, I just had to trim a little of the end and reclamp.DV8 1 :twisted:
MAZDA MAZDA MAZDA MAZDA MAZDA MAZDA MAZDA
2003 Protege5
1983 Rx-7 Limited Edition
1991 Festiva (soon to be a 121)
1991 Chevy S10 pickup (R.I.P.)
1990 Chevy S10 pickup Bagged on all 4 corners
I just replaced that little one you are talking about this weekend, it got a tear in it on my way home and was shooting coolant all over the place.. felt like a gummy worm when i took it off.Originally posted by eurotiva View PostClosely inspect the little hoses that come off the hard line that runs around the motor. I've seen so many of these bust.....I just did a motor swap last week because of the little hose that goes to the head right by the thermostat.
How big a leak do you have? Might be lucky and just needs a hose tightened up.. Now would also be a good time to go through and feel all your hoses and replace any soft ones.
1994 Camaro Z28, 6-Speed
1991 Festiva, Red 5-Speed
1992 Festiva, Teal 5-Speed -Sold
