I got the car home, I took of the clutch cable and started it and put it in reverse. the gears did grind a small bit. I made it go into reverse. it does move, but it seems as if it was an automatic. more gas i give, the more it moves. But does nothing unless i give it gas...any thought? Is the clutch just that bad, possibly thow out fork or....toasted trans? I might mention the guy told me it had a new battery, and looks like it. however it does start slow before it does finally fire, dont know if this has any bearing on it or not
B
B
