I remember when I replaced mine I had trouble getting em out so I just disassembled em and left the axel ends in. I was pry poppin the hell out of em but it was a no go...so I dropped the tranny and then pried/hammered and they came out. Of course, I was also doin a clutch soooo it made sense to drop the tranny for this. They can't not come out so just keep on pryin. And I'm with Future you should replace the seals if your not doing so.
Grrrrrrrr dang cv axles!!!!!!!!!!!
Easiest to just use a pry bar. But do so GENTLY, you can crack the case and end up with more troubles than you started with. I think that everyones experience is different with CVs. What works for me or someone else may not work for you or the next guy.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
another idea i used was find a mechanic with a horseshoe type wedge, aint perfect and ya gotta remember that case could crack! but after three days tryin different ideas it worked(albeit this was after i pulled the engine with them still on. kindof... good luck and cheerslight a man a fire and he'll stay warm for the night.
light a man on fire and he'll stay warm for the rest of his life.:faroah:
