did they even align the rear?? it takes shims to do that and most places won't install them or require EXTRA labor to do it...
back tires
Whenever I have any work done on the car that might affect the rear bearings, to include safety inspections, when I get home I jack up the rear wheels and wiggle the wheels to check for play, and then spin them to check for free rotation. These two checks cover too-loose and too-tight bearings. You just shouldn't trust these guys at the shop.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
the tire itself can give quite a bit, but the rim itself shouldn't move when shaken.Trees aren't kind to me...
Originally posted by FestYboy View Postthe tire itself can give quite a bit, but the rim itself shouldn't move when shaken.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
