back tires
    did they even align the rear?? it takes shims to do that and most places won't install them or require EXTRA labor to do it...
      said they cant align the reear but i agree with bearings
        Whenever I have any work done on the car that might affect the rear bearings, to include safety inspections, when I get home I jack up the rear wheels and wiggle the wheels to check for play, and then spin them to check for free rotation. These two checks cover too-loose and too-tight bearings. You just shouldn't trust these guys at the shop.
          sohow much give should the tire give????
            the tire itself can give quite a bit, but the rim itself shouldn't move when shaken.
              And it should spin freely; if it doesn't then the bearings are too tight.
