Any suggestions on reassembling pinch bolts with ball joints? For some reason the bolts are difficult to slide in and actually are stripping out before I can get them tight. Im thinking about taking it all apart, sliding the ball joint back out and using a large chisel to respread the jaws, in hopes of "squaring" everything up and then trying to reassemble. Just looking for anyone thats allready fought this battle. Thanks.
Ball Joint pinch bolts?
OH YES!! BATTLE!!! The ball joint is seated too far down. Raise it back out of the spindle some, and it will line up the way it should.Have owned 9 so far
thanks, i will give it a try. when i look through the pinch bolt hole, the large metal pin coming up out of the ball joint is actually partly sticking into the pinch bolt hole, and that is what is stripping the bolt(trashing the bolt threads as we try to push it through)
Never had that problem if the hole is lined up.
Pick up on the yoke some off the control arm so to keep the weight off the bolt.
Use some penetrating lubricate like Blaster.
Don't use a air wrench on this to remove or you could strip the threads.
Dean
Raleigh, NC
deanraleighnc@cs.comThe wife and I are attending this meet. Come convoy with us.Come to the 1st annual "Sunshine Meet" March 20th 2010. Details in the thread below.
http://www.fordfestiva.com/forums/sh...292#post295292
www.festivameets.com
Festiva Convoy video link [url]http://www.youtube.com/watch?v=VyFYJcFBc_g[/urlhttp://www.youtube.com/watch?v=ANbkG...eature=related
3rd Annual Festiva Madness. The largest Festiva Meet ever held of owners and their cars
2009 Festiva Madness link with pictures. 51 Festivas & 4 Aspires from eight states attended.
FM3 short 5 minute clip
Link to a short 5 minute clip http://www.youtube.com/watch?v=VFyy-zxgV5A
http://www.fordfestiva.com/forums/sh...ad.php?t=24695
link to 100s of meets pictures and short video clips.http://s1019.photobucket.com/albums/af316/festivameets/
4th Annual Festiva Madness meet will be held Oct 2, 2010 in Raleigh, NC
Cell is 919-271-5190 deanraleighnc@cs.com
I have had a couple get in a bind and ended up taking off the first threads thinking it was close enough to line it up as it passed through the hole. The easiest way I found to line it up is to take a pry bar between the axle and balljoint stud, and just nudge it down enough that the bolt passes through as it should. If it gives you ANY interference, it isn't lined up.Have owned 9 so far
You can also put a flashlight on the "far end" of the bore & see when the ball joint stud is more-or-less aligned with the bolt hole in the steering knuckle. You want to see the curved part of the stud, which is milled to accept the bolt, centered in the bore. If you see the "straight" part of the stud, it's either too high or too low w/r/t the bore.
Focustiva: Because I was told it was was impossible to fit a Focus bumper on a Festiva.
In memory of Dean Allen - V8 Festiva 1955-2010
It helps when you can still see...... I thought I had them lined up only to find out just how bad my eyesight is getting.Have owned 9 so far
LOL! I can certainly identify with that issue! Astigmatism sux!Originally posted by m715 View PostIt helps when you can still see...... I thought I had them lined up only to find out just how bad my eyesight is getting.
Just wait! It will come....Have owned 9 so far
^^ROFLMAO!!
AHEMM.... As an Officially Old Guy I'd caution you, young Batarang-Slinger, against discussing both "old" and "crack" in the same sentence!
HEY! WHO HID THE DANG META-MUCIL??
Why, you young whippersnapper! I'm gonna drink my Geritol and come and give you what-fer!Originally posted by batstiva View Post^^ You old guys crack me up.
just use a hammer to tap it up or down till the bolt slides in....no biggie."FLTG4LIFE" @FINALLEVEL , "PBH"
^^ exactly , unless you have good self control when wielding such an awesome weapon/tool. LOL"FLTG4LIFE" @FINALLEVEL , "PBH"
