I have had a good search through other posts and some come close to my problem, but not answered it.
The car in question is a 1993 Kia Pride 1.3 LX 5dr.
Now if it's cold or damp the car has trouble to keep running. It will fire-up (most times) and rev up to 2000rpm. Then it will have a mind of it's own, revs go down then up then down then it will cut out. If i try and pull away it will die down and stall, no matter how hard i try to keep it going. And if i blip the throttle it will die a little then rev up like it should do in the first place.
I've changes the usual things, dizzy, HT leads, plugs, air filter and put some carb cleaner through the fuel system, but still no joy :cry: . The only time it runs like it should is when it's warmed up.
I think it might have something to do with the auto choke, but i'm not sure what to do. A friend of mine said it might have a vacuum leak, but surely this would effect the engine, even after it has warmed up!?!
Sorry to go on, but this is really annoying me, and this forum is the best i've come across for these cars. So any help would be gratefully receieved. BTW, i'm from the UK.
