Hi, I need some help/advice.
The situation:
My Festiva is shaking when driving it. The car pulls to the left and right creating a shaking feeling when driving it. When I drive it, even at low speeds you can see the steering wheel go back and forth little bits. The problem that started last week, but was not as bad as it is now.
Other Information:
About 3 weeks ago I replaced the front and back brakes as well as the rear bearings. When I replaced them the CV boots all looked intact, but that was then. I also just checked the wheel bolts and they are all nice a tight. The tire pressure is also good.
So What are the potential problems and what do I do to fix it?
Thank you for any help given!
Tim
The situation:
Other Information:
Tim
