Originally posted by roycehof
Then when the oil level drops (bad seals, to much play in the diff carrier bearings etc)
That 5th gear can get abused pretty good, even though it's the least used gear.
Although you've gotten it back together at this point I'd say a chunk of tooth came off and got in the syncro, that's what I had happen. I was shocked to see a piece of my fifth gear missing because I so rarely ever use it.
