ive noticed yesterday that my car was running hotter then usual the needle was 3/4 to H and noticed the fan was not kicking on. I also tried my interior fan to no avail. I turned the car off then noticed the cooling fan turning on and my interior fan started as well. What could be the problem?? the fusible links?? or relay?? please help
over heating problem
So, with the car running, neither the cooling fan, nor the blower work, but with the car off and key out, they both work?
Two commonalities (how's that for a 50 cent word?) appear to be the main (center) fusible link and the only 20 amp fuse in the panel under the dash. I'd check those. The fusible link first, pull the jumper carefully and check for corrosion, then check the interior fuse. I don't know the number placement off the top of my head, but according to my owner's manual, it should be the only 20 fuse under there.
1989 L - 247K miles Slick
Use these instead...(see post 4). http://www.fordfestiva.com/forums/sh...highlight=fuse
Make sure you have the long ones. The parts store can show you the difference.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Like these.
Originally posted by jtugfestiva View Post30-40-30 right the part store only have the 40 fuse. which one is the one giving me the problem the main or the EFI??? What problems did you folks have with the old wired fuses??90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
