I've seen somewhere in the past that on a bp engine or b8? that the crank pulley will work from a festiva. My question is since the b8 uses a bp block. Will all the parts that bolt onto the crank fit the b8 off the festiva? By all parts I mean pulley, keyway, bolt, and the timing belt gear. Also could I not just look for the parts for a bp engine instead of a b8?
Im trying to figure this out because its easier to get those parts for a festiva then for a protege. I dont know if it will help but my crank is the big nose not the small.
p.s. If anything I said above is incorrect please correct me.
Thank you in advance -Daniel
2009 Festiva Madness link with pictures. 51 Festivas & 4 Aspires from eight states attended.
