I have a new coolant leak on the right side of the motor (the side facing the grill) It is where the two metal coolant tubes connect. Im not sure what they are called but what would be the best fix for this? Thanks
Coolant leak.
sounds like you may be talking about the bypass joint... there is an o ring in that joint that comes with the water pump, but often doesnt get replaced... not sure if you can take apart w/o disconnecting from the water pump... i'm doing water pump now-and that o ring. ill let you know what i find... lol you could always try jbweld if you are never planning to take that apart. i hear people have sealed cracked blocks with that stuff!light a man a fire and he'll stay warm for the night.
light a man on fire and he'll stay warm for the rest of his life.:faroah:
Replace the o-ring..........do it right once or find time to do it twice.-Greg
Redneck Engineer
FOTY - '09
Any auto parts store will have the Oring you need. Just bring the old one with you to match up.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
and you can pull it w/o touching the pump...Trees aren't kind to me...
I would say to unbolt it. Make sure to get the fastener over on the driver side also. If the female part of the coupling is rusted beyond recognition you have a couple of options. One is to find a good used one. The other may be to cut the tube and simply slip on a piece of heater hose in place of the joint. Hope this helps.
ouch, man! just finished mine... you may consider(not sure if this is safe for coolant system) spraying some penetrating fluid in there first, one that has capilary action, cus mine wuz rusted pretty good... glad i changed it though the ring was shot. wasnt leaking yet though. good luck! i had to take off the exhaust down pipe to get at the bypass bolt cuz i could not find my 14 mm wrench!!! or was it 12... either way! cheerslight a man a fire and he'll stay warm for the night.
^fixed!Trees aren't kind to me...
well ran it tonight for a while and drove it around, doesnt leak at all! Got all the tires fully inflated and all lugs on, tightened down the rear wheel bearings which were very loose, and noticed something very funny about the lights. We took it for a spin on the road and it lights everything up perfectly, but the lights are crossed haha. Ill tweak that tomorrow....Tyler
91 Festiva, 5spd, B8 swapped, now for paint and suspension
