So I did the aspire brake swap and got new tires. I also replaced the passenger side half-shaft.
I'm getting tons of wheel/tire howl. I torqued the axle nuts properly and adjusted the toe-in to be about .25". I didn't replace any of the bearings but shaking the wheels they feel solid. When I go over 30-40 mph, the howl starts. It is definitely not a grinding noise. If I go perfectly straight it is not as loud. It definitely gets louder when turning. More so when turning left. Could this be just tire howl from lack of proper alignment or do you think it's the wheel bearings? I hoping to just align it once. Any input from past experience would be greatly appreciated. Thanks!
