Surging, irregular idle, random no power on accelaration
  • #61
    now that i think about it, it looks like the coolant temp sensor but why would it cause my car to freak out?
    1990 Ford Festiva 196k Automatic (Gone) " It's a small car so you gotta drive it like your ticked off... Small cars need to be driven fast"
    :spam1:is delicious
    • #62
      fail-safe feature? a really stupid one if it is.
      -Zack
      • #63
        threw it into limp mode....how is it a coolant sensor....no coolant flows through those intake runners.
        Originally posted by Kofkof_00 View Post
        I plan on updating this thread with everything I try. :S
        I still think it is your distributor.....coil pickup and crank position sensor is inside of it.
        • #64
          i dont know but the sensor i keep finding online looks just like it
          :spam1:is delicious
          • #65
            Heres proof of the coolant temp censor is causing my car to freak out
            The coolant Tempurature censor is what is causing my problems and heres proof
            :spam1:is delicious
            • #66
              Originally posted by Ephet View Post
              This is what is causing my Festiva to run the way it was
              Originally posted by Justin View Post
              Sounds similar to a CTS Sensor going bad. This Sensor Uses Most of your Electrical Volts on Starting/Idling up until Operating Temp. If you have a Ohm Test Gauge hook it up to the terminals across the sensor after uplugging the connector should be cold (not started)(2000 to 3000 ohms) & once the engine reaches operating temperature (180Degrees)(200-400 ohms). Its the best explanation I can Come up w/on Your issues.
              That sensor is the Coolant Temp Sensor which monitors the coolant passage temp & sends a signal to the Engine Computor. However, Disty Could still be the Problem but I recommend he try the cheaper route & replace the sensor first. I wonder if he's tried to see if all the wires are getting spark?
              http://www.youtube.com/watch?v=rKqtcENg5R0
              That is a Coolant Temp Sensor though so he is right & does affect Motor as Seen here in the video.
              • #67
                CTS can cause ecu issues simply because the sensors sends temp readings to the ecu in order to adjust timing. When a car is cold, engine timing is advanced in order to warm the engine to normal opperating temps. Thats why most people notice there car runs better just after a starting it. Once normal the ecu will level out the timing and it will adjust depending on the load the engine is going through unless you have something else failing.
                I went round and round with CTS on a few isuzus and DSM's.
                Not sure but isnt the CTS on the thermostat housing?
                89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
                My site: 20tessa.sytes.net
