91 Festiva, Gears slipping? What needs fixed?
  • 91 Festiva, Gears slipping? What needs fixed?
    Aloha!
    I need to diagnose what to fix. I have a 5 speed manual transmission. When driving in any/all gears, there is a frequent slipping of what feels like a gear. It jolts the car very harshly until I take my foot off the gas, the RPM slows, and the slipping stops. The car wont pull forward when the slipping happens but the clutch doesn't seem to be 'popping out' of gear but slipping while in gear instead. Is this the clutch? Is this the transaxle? It seems the CV joints/boots are in tact so I don't know if it could be that.
    I plan on pulling the car apart Saturday to further investigate but I would appreciate to hear from anyone with more experience and suggestions on what it might be.
    Thank you and happy holidays!
    sounds like the clutch is toast or the cable is mis adjusted
      I agree with BP-Festiva, if you leave it in gear and stomp the gas and it slips and when you let off you feel it grab...clutch is toast.
        sounds like a clutch that went.
        1973 Cb750 haven't touched it yet with no idea what I am planning on doing with it
        1978 25th Anniversary edition Corvette
        1983 Chevy Elcamino
        1993 Ford Festiva GL
        2003 Hyundia Santa Fe ( Wifes Daily driver)
        some old dodge motorhome I have no idea of the year
          Add me to the "needs a new clutch" list.
            Ditto.... add me to the list as well...
            My Fleet:
              Clutch.
                Thank you all so much for the quick responses! I will check/replace the clutch and get back to you. Have a great Holiday!
                  Clutch test:
                  Block wheels and set parking brake
                  put car in fourth and rev to 2,000 RPM
                  slowly release clutch
                  If motor doesnt stall within five seconds the clutch is slipping
