I was driving down the highway today and my check engine light came on...any ideas how to get it to go off?? I sure do love holidays!
Check Engine Light!
check this out for how to check the codes:
link to sticky on what codes are what:
-Aspire brake swap COMPLETE!
they only thing that ever set off my CEL "check engine light" was the O2 sensor... i had one of those cheapo A/F gauges and when ever i was driving and it wasnt acting "normal" the CEL would come on... then it would start acting normal and the CEL would go away... then i got a new one and it never did it again... you may want to get a new O2 sensor, they make your moror run smoother if the old one is worn out and it will also get you better MPGLast edited by sasquatch; 12-25-2009, 11:22 PM.
Mike, AKA the sasquatch
Originally posted by aglatfe1 View PostI was driving down the highway today and my check engine light came on...any ideas how to get it to go off?? I sure do love holidays!
Man, what is it about Festivas and the holidays? Seems there are several threads or posts about problems that cropped up in the last couple of days. My left rear tire decided to go flat for no apparent reason yesterday. Pumped it back up about noon, or so, yesterday. Hasn't lost an ounce of air since then.
1989 L - 247K miles Slick
Originally posted by batstiva View PostThere's always the option of putting a piece of black electric tape over the light so you can't see it.:p90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by halac0ax View PostUnhook the battery for like 10 minutes usually does it.. but I would get the code first just in case its something important.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Originally posted by aglatfe1 View Posti don't really want to touch anything with my battery...i might fall on it and break it!
Only time my cel ever came on- it would blink on and engine would hesitate during warmup- only would happen a couple of times a week. I checked- code for ect sensor- replaced ect and no problems since. Definetly check code before clearing, or it will most likely be back.186,000 miles per second is not just a good idea, it's the law
1990 yellow L+ (l8ly)
1990 yellow L+ (sunryz)
1992 aqua L (agua)
1993 blue L (aurora)
