Hulkstiva is sick!!
  • #16
    Originally posted by David88 View Post
    lol.
    So did it stop smoking/squealing? Have you tried it again?
    Haven't been able to try it again. Luckily a guy I work with lives in my apt. complex and he was heading to work right when I was so I just grabbed a ride with him. Hoping the alt. is just froze up....guess I'll check that first as soon as I get out of work tonight
    • #17
      I think you are going to find the alt. is seized/ frozen. Just MHO.
      30 degrees Greg?? When's the snow starting?? Good thing you're not headed to Sea World today, eh?:p
      1988 L - 232K miles Batstiva
      1989 L - 247K miles Slick
      • #18
        Thanks for all the quick responses guys!
        • #19
          I'm waiting for the snow. It's cold here. Ocean breeze @ 30 degrees burr. Yea we got luck for new years it stayed 73 thru the night.
          Let us know what's up with Hulk.
          -Greg
          Redneck Engineer
          FOTY - '09
          • #20
            Originally posted by eurotiva View Post
            I can't preach the b8 anymore. My BP is goin in today....if it will warm up. It's high 30's.....
            Was outside working on cars today. 15 degrees, light breeze, felt like 0.
            • #21
              Ok, just got off work and got under the hood. There was definitely a good bit of belt dust/residue from the alt. belt. Took that off and checked the alt. and it spins freely. So I cranked up the car and it ran fine. Guess I just need a new belt?
              • #22
                All pulleys spinning freely? I don't see a bad or worn belt smoking, unless it was tensioned too tight.
                • #23
                  Maybe the belt was siezed. 8^)
                  • #24
                    Yep, everything was spinning freely....don't really understand it myself
                    • #25
                      A friend had a 66 charger with a 383 cu. in. v-8. He went out to start it one morning in the winter and it did what your car did. His water pump had froze up during the night. I took off the radiator cap and there was a green slush in the radiator. Let it thaw out for a few hours and it was fine. Evidently the anti-freeze had lost it's strength and was no good any more. You may want to check your anti-freeze and make sure it's up to par.
                      1960 willys pickup
                      1967 jeep cj5
                      1988 festiva
                      1989 festiva
                      1990 festiva for parts
                      1991 s-10
                      • #26
                        Man, that's gotta be it! I have been meaning to put new anti-freeze in the car because I know I've got a weak mixture in there. Good call!!
                        • #27
                          I was thinking that when I asked how cold is was there. If it freezes at 30 degrees you better change it quick. It must be nearly straight water.
                          • #28
                            Another 30 degreen morning....started the car to get it a little warm and then water started pouring out of the bottom of the engine. A round piece of metal fell off as well, looks kinda like a bottle cap.....freeze plug? What do I do now?
                            • #29
                              You can get new freeze plugs. They even have a rubber repair one that has a screw to tighten up and hold it in.
                              93 GL modyfied!!!
                              :fish:
                              • #30
                                Sweet. I just did some searching on here and found out it's definitely a freeze plug. Any experience with the rubber ones? If I go with another metal replacement, any special way or tool I need to put it back in?
