Originally posted by David88
Hulkstiva is sick!!
I think you are going to find the alt. is seized/ frozen. Just MHO.
30 degrees Greg?? When's the snow starting?? Good thing you're not headed to Sea World today, eh?:p
1989 L - 247K miles Slick
Thanks for all the quick responses guys!"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Originally posted by batstiva View PostI think you are going to find the alt. is seized/ frozen. Just MHO.
I'm waiting for the snow. It's cold here. Ocean breeze @ 30 degrees burr. Yea we got luck for new years it stayed 73 thru the night.
Let us know what's up with Hulk.-Greg
Redneck Engineer
FOTY - '09
Originally posted by eurotiva View PostI can't preach the b8 anymore. My BP is goin in today....if it will warm up. It's high 30's.....90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ok, just got off work and got under the hood. There was definitely a good bit of belt dust/residue from the alt. belt. Took that off and checked the alt. and it spins freely. So I cranked up the car and it ran fine. Guess I just need a new belt?"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
All pulleys spinning freely? I don't see a bad or worn belt smoking, unless it was tensioned too tight.
Maybe the belt was siezed. 8^)sigpic
Originally posted by batstiva View PostAll pulleys spinning freely? I don't see a bad or worn belt smoking, unless it was tensioned too tight."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
A friend had a 66 charger with a 383 cu. in. v-8. He went out to start it one morning in the winter and it did what your car did. His water pump had froze up during the night. I took off the radiator cap and there was a green slush in the radiator. Let it thaw out for a few hours and it was fine. Evidently the anti-freeze had lost it's strength and was no good any more. You may want to check your anti-freeze and make sure it's up to par.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
Originally posted by worfdog View PostA friend had a 66 charger with a 383 cu. in. v-8. He went out to start it one morning in the winter and it did what your car did. His water pump had froze up during the night. I took off the radiator cap and there was a green slush in the radiator. Let it thaw out for a few hours and it was fine. Evidently the anti-freeze had lost it's strength and was no good any more. You may want to check your anti-freeze and make sure it's up to par."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
I was thinking that when I asked how cold is was there. If it freezes at 30 degrees you better change it quick. It must be nearly straight water.sigpic
Another 30 degreen morning....started the car to get it a little warm and then water started pouring out of the bottom of the engine. A round piece of metal fell off as well, looks kinda like a bottle cap.....freeze plug? What do I do now?"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Originally posted by 25Horseplay View PostYou can get new freeze plugs. They even have a rubber repair one that has a screw to tighten up and hold it in."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
