i have a 93 it started running bad it would idle but when i pushed the gas it would die i changed the plugs wires cap button fuel filter it started and went but missed bad when i gave it alot of gas that worked itself out but now the gas mileage has gone to crap its using twice the gas before all this happened i ran it really low on gas then filled it up the filter was nasty but i also think i might have got some bad gas with water in it anyone got any ideas on what it could be i have not put any new gas in it yet
gas mileage went to crap
+1 on air filter, and I will add clogged catalytic converter. Also O2 sensor; and stick a bottle of fuel system cleaner in the tank.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I'm a big fan of Sea Foam. I've seen it clear up some nasty miss and hesitation problems. I had a weird hesitation in my car when I first got it. I mixed a bottle of Sea Foam and a bottle of Chevron Techron, put it in the tank, and then filled it up. That took care of about 95% of the problem after I ran through that tank and got better a couple of more fill ups later. The more I drove it, the better it ran.Originally posted by TominMO View Poststick a bottle of fuel system cleaner in the tank.
you probably ruined the o2 sensor with it running with a miss, replace it with a denso unit and your milage should come back.Trees aren't kind to me...
