Window Mechanism
  • Window Mechanism
    What is the best and easiest way to pull a window mechanism off of a Festiva? Not the crank the insides with the gear attached to it. Can I just pull of that geared part? I tried to pull on at the JY yesterday but could not cut the cable that was running through it. I have another question but can't remember what it is right now. Could you also PM me a response so I can see it at work . Thanks in advance.
    :festiva::newb::festiva:
    There's a few nuts/bolts attatching it to the door. Take those off and the whole assembly comes out in one piece
      I took out those 3 bolt that attach it to the door but it was attached to the whole window assembly with braided wires. Do I have to pull the whole thing? I really only need the gear assembly (mine when purchased did not have a crank or the gear part, it was broken half way in).
        Yeah, there's a few more bolts holding the rest in...probably easier to just take the whole deal out and swap it into yours
          ^ x2..... It's just the 2 bolts holding the window. Then 2-4 more holding the track. You almost had that one if you already had the crank un done.
          -Greg
          Redneck Engineer
          FOTY - '09
            Yeah dont wreck an assembly trying to do it the easy way. There is no easy way. You have to remove and swap the entire assembly.
            - Unknown
            - Quentin Crisp
            - Bumper Sticker
              Thanks guys, I was kinda expecting that would be the answer but I just wanted to make sure. Thankfully there are 2 in my local junk yard
