Reason: I have 4 axles, 1 of which is brand new. I don\t plan on getting another aspire (to drive anyway) Is my only alternative to sell them on the aspire site?
Can aspire axles be used in a festiva (any combo)
Aspire axles are Very slightly longer. If I remember 1/4" or something like that. I used em in my festiva, but I was using aspire struts and spindles too. (with the aspire 5 speed)Previous:
1991 GL. (01' ranger lights!) P/S,A/C Sold to Mum.
1990 auto. hacked up rally toy.
1988 5 speed. The pile
1993 5 speed.
1995 5 speed aspire. Gutted for the 90' auto.
WHATTTTTTTTT? Perris? Another socal guy? Few and far between we are. I plan on using lots of aspire things, such as the 5 speed and full swap as well. How is it longer, more threads out of the hub, or is everything pushed out more? as long as it works with no binding then game on ill deal with it even if it looks funny. Wider wheels are the idea in the future as well.1993 GL 5 speed
Everything would be pushed out more, not just longer threads on the axle; so they couldn't be used, since the LCA length and tie rod length determine the position of the knuckle.Originally posted by getnpsi View PostWHATTTTTTTTT? Perris? Another socal guy? Few and far between we are. I plan on using lots of aspire things, such as the 5 speed and full swap as well. How is it longer, more threads out of the hub, or is everything pushed out more? as long as it works with no binding then game on ill deal with it even if it looks funny. Wider wheels are the idea in the future as well.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
You would still have the tie rod issue; so just pushing the knuckle out farther doesn't do it. Short answer, just use Festy axles, sell the Aspire ones.Originally posted by getnpsi View PostHm so which is it? if i grab aspire control arms it works? New control arms cost less than more axles.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
