It can also be the bushings just under the gear stick itself where it connects to the rod to the transmission. I know that is what was wrong with mine, and it was only 1 bolt and 1 nut to remove. The replacement bushings can be had at Ford / Mazda dealers, or you can use a door hinge shim kit from your local parts store. As far as the ones by the transmission, I think they are the same way, but I'm not 100% sure. Good luck and welcome to FF.com!
The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!! My Fleet:
Thank you for finding that jmye. I was looking for the pictures on my camera to add them to this thread, but that works just as well. This fix helps more than you would think. It was like night and day.
