Is the bang bang coming from the intake or the exhaust? General rule of thumb is backfiring thru intake is electrical\timing, while thru the exhaust is fuel.
90' Festy has NO power when driving..
Also possible is that the timing belt has slipped a tooth or two. Maybe the PO was trying to compensate for that, not realizing it was a valve timing issue, not an ignition timing issue.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
here's a Q: is the engine rev limited? how bad were the plugs when you pulled them? there's a potentially bad/clogged cat in your future. unlikely that it skipped a tooth on the timing belt, as if it had, you would find power high up in the RPMs and the idle would be lumpy(ish).Trees aren't kind to me...
Just did a compression test. all clyinders within 5 psi of 175. I did it with a cold engine, because i don't want to run the motor more than i should. So i figure it would be a little more when warmed up. So does that rule out headgasket??
The car doest have a cat, so a clogged one is out of the picture. The plugs were REALLY nasty when i pulled them out. I had to spray wd40 to try to penatrate down in there, and use a breaker bar to get them out! im lucky they didnt break off in head.
It is a little plate that should have a "T" on it with little lines like a ruler. It is in front of the crank pulley towards the front of the car, you might need a flash light ot see it. Its inbetween the water pump pulley and the crank pulley, if you remove the MAF and airbox you can see it better.Originally posted by festiva208 View PostAlso, could someone maybe show a picture of were the timing marks are..i looked all over that timing belt cover and could not see themLast edited by wybnrml; 01-24-2010, 09:45 PM.'90 LX
yeah... good head gasket, no clogged cat, bad coil..... replace coil.Trees aren't kind to me...
Don't forget that fuel injected cars use the mark on the BACK of the timing cover. It is a single slash, not the guage on the front of the cover. This is a common mistake which results in a non running car! The front timing guage is only used on carburated cars.Have owned 9 so far
changed fuel filter today, it was clogged up and a buch of nasty old gas came out of it. Still has no power and is hesitant. Will play around with turning distributer tomorrow, don't have the money to have someone with a timing light mess with it, so by the way i described it running, should i gradually turn it clockwise (advance?) or counterclockwise (retard?) and see how it runs then...I know it's a halfassed way, but im not putting any more money into the car. If that does't fix it then its going up for sale or scrapyard...
