Originally posted by festiva208
90' Festy has NO power when driving..
Clockwise is retard, counter is advance I think.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ok thanks! So do you guys think by the way it runs (makes a banging sound right before it starts, idles fine, hesitant and cuts out when giving throttle, hesitant and about dies when taking on and having no power when driving, occasional backfire when driving) that it needs to be advanced or retarded? I know its probably hard tellin' without being there to listen to it, but just need an opinion.thanks
-drew
If you had a bunch of trash come out of the fuel filter, maybe the fuel sock is plugged up as well. I had that problem with mine.Last edited by MONSOON; 01-27-2010, 08:14 PM.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
it's clockwise=advance (as you're looking at the dizzy from the driver side) and replace your coil.....Trees aren't kind to me...
Ok i'll check the filter in the tank tomorrow or whenever i get time next. i take it you have to drop the tank because it sits down in from the top? Didn't mess with timing yet because as some said, i don't know how it would just go out of time. Im also going to check air box for a clog because i saw a mouse running around in dog house when i popped the hood. maybe he made a nest clogging up the air flow, even though its acting like its more starved of fuel than it is air (when i pulled new plugs to check color they were a real light bronze color) Still need to try out new wires..want to check all things that won't cost me money first!
No, tank has an access port inside the car.Originally posted by festiva208 View PostOk i'll check the filter in the tank tomorrow or whenever i get time next. i take it you have to drop the tank because it sits down in from the top? ..........
checked in tank filter today. Looked a little dirty in some spots but nothing thats going to effect efficient fuel pick up. I got my sights on other things and don't feel like putting anymore money into trying to find the problem so i'll see what the scrap yard will give me, and if its not good enough i'll try to sell it or part it out on here. Thanks for all the advice everyone!
If I could help you I would but I don't know what's wrong with your car. If you want to sell it to a scrap yard, call me, 502 645 8439. I'm just a few miles down the road from you.Originally posted by festiva208 View Post
took it to the mechanic and the timing is fine. He said that he's pretty sure its 1 or 2 injectors that are plugged up. I know the #1 cylinder is one of the cylinders not getting fuel because the plug is whiter than the rest. He checked them with an ohm meter and they are ok, just clogged really bad. I've already ran some injector cleaner through it, but hasnt helped much. Hopefully i can find some used injectors, or possibly a whole rail w/ injectors.
send them out to be cleaned/ballanced, it's cheaper than buying new ones by quite a bit and takes only a day or two to do it.Trees aren't kind to me...
Poverty produces creativity
