I have rear defrost on my festy, it does not work. The dash switch was bad, I just replaced it. I now get the light on dash to come on, but defrost still does not work. Anybody tell me how to troubleshoot this thing? I searched, found out how to repair breaks, but not much on figuring what my problem is with it. Thanks....
Rear defrost help
Rear defrost help
Dan
http://www.reverbnation.com/main/sea...t_songs/266647Tags: None
Have you checked to make sure you have power at the defrost itself with switch on? May have cut along the line or something.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Or you don't have a ground to chassis from the hatch. See if a test light can help find out at the furthest point, then work your way back. The grids have a bad habit of being damaged too.
Does your licence plate lighting work?Have owned 9 so far
Thanks... I will try both you guys ideas!Dan
Even if there was damage to the grid lines the rest should work. At least in our old honda it did. My buddy was putting tint on the rear window when he scraped a couple of lines while cleaning it with a razor blade. Most of them worked, but you could definately tell which ones had a break.
So I would have to say you are not getting power to the back or it is not grounded.Man should eat when he can for Man does not know when his last meal will be.
