Windows Question???
  • Windows Question???
    I've replaced both window regulators on Hot Rod because the old ones didn't work at all. After several months both windows are rolling up crooked. I've tried making adjustments but keep having the same problems. They both appear to be on track but I'm having to hold the windows up straight to roll them up completely. My inexperience is showing I've done the search thing and haven't found answers. Any suggestions?
    '93 Festiva GL / "HOT ROD"
    '02 F-150 Supercrew
    '02 Excursion 4x4
    '98 Jeep Cherokee Classic Limited
    I believe I remember seeing some have lubed the tracks the window rides in and that helps them not grab on the way up.
      Thats what i do to mine . Just use a little of that white grease and you are back in business.
      IF you never succed at what you are trying to do then maybe failur is your style
        ahhh mine do this too so thats the trick. good because i hate it
          ^we can take care of that when i see you Fri.
            i read on one of the threads that vaseline works great. I used vaseline myself and I would have to say my windows slide up and down smoother than ever. before i would have to shove it down and up.
              Spray silicone works too.
              Ian
                hmm, Im going to have to try one of these... Just today I was trying to fix my window from doing this, and I couldn't see anything wrong... lol
                -Josh R
                  Yup lube lube lube!! And yes I am still talking about your windows!!
                  The new keeper of Uncle Fester!! 88 5-speed, efi, now with ac!
                  1988 LX ~sold~
                  1992 Blue GL auto, ac ~sold~
                  2008 Nissan altima 3.5sl loaded <lease returned>
                  1996 Nissan maxima <sold>
                  2002 ford f350 crew cab short bed diesel
                  Just remember, it could be worse, you could have a fork in your eye!!
                    Great advice guys. I'll try that this weekend.
                    '02 F-150 Supercrew
                    '02 Excursion 4x4
                      If I use KY Intense, will my car tell me I'm the man??:p
                      Just hit mine with some spray silicone, makes a world of difference. Don't have to be Ahnold to roll them up now.
                      1988 L - 232K miles Batstiva
                      1989 L - 247K miles Slick
                        who...an old,flabby ex body builder/actor......hehehehehe
                          I have to suggest the spray silicone works best because it doesn't attact dust like a paste lube does. It also does not last as long though, so you must reapply it about every two months, and if you go to paint the car, you will have one *%@(*& of a time avoiding fisheyes in your paint. Mazda regulators get play that cannot be adjusted out with age, and the weatherstrips shrink up are the two real culprits. Roger sold me one new set of weatherstrips a few years back. You think YOUR windows are hard to roll up!!! They are just now starting to get set to the place you hope the crank won't snap off in your hand while rolling it up! BTW, I have been an Auto Glass tech for 26 years.
                          Michael
                          Hey Bat!! Have ya tried that out yet?
                          Have owned 9 so far
                            ^^^^^^If I use KY Intense, will my car tell me I'm the man??:p
                            haha thats great:p
                              I dont think so, I tried it on my car and all it did was ask, IS THAT ALL YOU GOT? It kinda hurt my feelings.
