Have a 1990 Festiva.
Yesterday i smelled gas.
Looked at the filter i replaced in May 2009 which looks like the picture I attached below. The filter was wet at the top and i could see gas dripping. Went out purchased a new filter and replaced it.
Not being a mechanic or knowing anything more to do..i tried starting it and while the car would crank, it wouldnt start. I could see the new filter filled with gas however there still is a slow drip.
Well i guess i tried to start it too many times as now while i turn the key, see lights on the dash and can hear the fan...the car wont crank. Not sure if i have ruined the starter.
I recall last year someone saying disconnect the battery and depressurize the system prior to the new filter install. Not knowing how to do that..and not doing it probably is causing my problem.
Any suggestions ?
Any suggestions ?
