Bought my white 92L (Not Running) from a Guy that Bought it from a Girl. The 1st thing I Noticed was that the Clutch falls Straight Down VERY easy but manages to Pull itself back up if let off so the Return Springs works. I Popped the Hood & Had a friend push the clutch in. Everything outside the Transmission seems to be operating perfectly. The cable & Swing arm mounted on the trans Moves back & fourth while pushing in the clutch. I had asked the guy I purchased it from what the issue was w/the clutch & His Reply was "I'm Not sure but the Girl mentioned Something happend while they were driving down here from GA". My First thought is a good ol' clutch replacement but want to double check your opinions. thanks
Transmission Not Engaging
thats why I mentioned (Not Running) above but I guess I have'nt Fully Tried it Yet as the Battery is Dead. I may have to wait till it gets a bit warmer & Get a Good Battery in it to see if it will even crank. I was Just assuming it don't run since the clutch seems like its not engaging or disengaging anything. The Clutch is Very easy to push down hardly any effort.
Springs on the pressure plate are probably worn out......Replace clutch.-Greg
Redneck Engineer
FOTY - '09
make sure the axles are fully seated in the trans before attempting any other repairs.Trees aren't kind to me...
Originally posted by FestYboy View Postmake sure the axles are fully seated in the trans before attempting any other repairs.
Justin, Whats Up With Capitalizing The First Letter Of Some Words?
to answer your question- axles will need to come out for the transmission, then transmission removed to install the clutch on the flywheel.
-Aspire brake swap COMPLETE!
Originally posted by ejp2fast View PostJustin, Whats Up With Capitalizing The First Letter Of Some Words?
Re-read your question & let me know why you did it first :tongue1:
sry, i was mentioning that if an axel is popped out of the trans, it will exibit the symptoms you have (sudden loss of engagement)Trees aren't kind to me...
Originally posted by FestYboy View Post(sudden loss of engagement)
1989 L - 247K miles Slick
Originally posted by ejp2fast View PostJustin, Whats Up With Capitalizing The First Letter Of Some Words?'93 Blue 5spd 230K(down for clutch and overall maintanence)
