lol car died on the freeway
  • lol car died on the freeway
    88 carb just died out of the blue after i installed msd blaster coil. read up a few threads but i cant understand most of the parts without seeing pics. ill try to get a haynes repair manual. i also have a msd box 6200 that i didnt install just yet.
    seems that the distributor seems to be the problem. the jumper wires are fine but ill do the fuse thing soon. im not getting any spark as well from the coil and wires....
    as far as the msd coil and box its just the two heavy wires (neg and pos), 12v switch, and the two wires that connect to the blaster coil???
    yes, the MSD coil fried your ignitior module inside the distributor. The primary resistance is too low, causing excessive amperage draw thru the module.
    No, the MSD box should also have two or three pickup wires. They connect to a plug on one end of the box. These need to get connected to a good distributor.
    Jim DeAngelis
      if the MSD's primary is too low, that makes me wonder about the accel super coil i have in Scrappy (been there 3 years now). not saying it's gonna hurt anything, but it may be a more compatible alternative.
        I been wondering about the connection between MSD Blaster coil use and failed igniter modules.
        We have had more than a few lately.
        Does someone make a coil that wont cause the excessive amperage draw and yet still give you the wanted higher output voltage?
        Which leads me to the question, if your running a higher output voltage are the recommended/OEM plugs and wires still the best option considering the higher voltage?
          just need to find a coil with more than 3ohms primary resistance. Blasters are typically 1.5.
          Jim DeAngelis
            I just did a search on Summit Racing's site. Just do a basic search for "ignition coil" and then on the left side of the page you can narrow your results. Pick "Ignition Coils" from that menu. Then using the narrow results bar again - scroll down the screen until you see where you can narrow results based on "Primary Resistance" and click on "Show All". Near the end of this list select "3.000 ohms".
            Hope that helps
            WWZD
            Zulu Ministries
              ballast resistor
              I fried my module in the distributor with my Accel Super coil. I thought I didn't need the resistor. I was wrong. Make sure you put it in.
                shouldn't need a resistor with a coil greater than 3.0 ohms
                Jim DeAngelis
                  so how do get a resitor? sorry bad at electronics
                    just search summit for "ballast resistor"
                    Jim DeAngelis
                      cool.
                      even its for msd? and how would i hook it up???
                        odd, i have had no problems with my blaster ss coil and msd btm....knock on wood. I should get a spare dist/ignitor next time i go to the treasure yard.
                          if you're running an MSD box, you don't need a ballast resistor. You only need the resistor if you're running a coil with less than 3ohms primary resistance directly off of the ignitor in the dizzy.
                          Jim DeAngelis
                            hey o found this:
                            MSD/.8 Ohm ballast resistor
                            will this work with the blaster 2 coil and 6200 box?
                              Originally posted by LBC_FESTIVA View Post
                              hey o found this:
                              does that answer your question?
                              Jim DeAngelis
