The b3 engine uses a wasted spark ignition
  • The b3 engine uses a wasted spark ignition
    The b3 engine uses a wasted spark ignition. I had found out. That's why when I try to adjust the ignition timing to 10degrees btdc it always be out of power. The thing was that because it uses a wasted spark system it fires twice for every complete cycle, so the timing light will read always half the timing it's really is. So if I set the light to 10deg btdc, in reality it is 5deg btdc. Anyway, I adjusted to 20deg btdc on the timing light and it is 10deg btdc. Now my question is, can the timing be advanced a little bit more from stock to make more power?
    Thank you very much.
    :festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
    huh? wasted spark? so it is sparking between the power and exhaust stroke? that can't be....
    -Aspire brake swap COMPLETE!
      I run mine @12-13 and no concerns so far. It cannot be wasted spark type as the rotor button only rotates at camshaft speed(half crankshaft speed).
      186,000 miles per second is not just a good idea, it's the law
      1990 yellow L+ (l8ly)
      1990 yellow L+ (sunryz)
      1992 aqua L (agua)
      1993 blue L (aurora)
        Sounds like its time for a new Rotor & Cap! Or you've really got an odd issue with your ignition system. (Poor-man's MSD?)
        There appears to be a "wasted" pulse of the injectors. This occurs in Festivas, but not Aspires. If you have a real good look @ the wiring diagrams in the Haynes manual you'll see the difference: 2 circuits instead of 4 individual on the Aspire. I've asked many engineers and a few old race hounds about this; it looks like a real economy and emissions disaster at first glance. It turns out to "supposedly" not make that much of a difference in fuel delivery timing, it stays on the intake side and gets a chance to atomize, and doesn't just pump out the exhaust. My common-sense still thinks its odd.
        I have no experience with Aspires, so perhaps someone can tell if their injectors have a higher flow rate and that is why they were able to change things.
          Can you tell me what numbers, names you see on the distributor itself?
          Is it a Mitsubishi distributor?
          I noticed a difference in the B6 and B3 distributor. My first thouht was that the mitsubishi (b3) fired twice as many. I dont have them both here to look, but I will get back
            If it has a distributor I would say it is not wasted spark. The Wasted Spark system that I know of is on a Miata B6, it has a timing unit off the cam and runs two ignition coils.
            Aspires and Sways all around, Miata B6 installed, KYB G2Rs just installed in front. Wish for coil overs someday.
              It is not wasted spark. It CANNOT be wasted spark with a distributor. Wasted spark requires a transformer type coil to fire two cylinders simultaneously.
              What I suspect happened was that you did not disconnect the vacuum advance before you tried to set base timing.
              Jim DeAngelis
                I found this.
                The Mazda B engines are listed.
                  The two distributers I am looking at differ in that the mazda one has 2 magnets on the pickup coil and the mitsubishi has just one magnet.
                  Now, i dont know what difference this makes.
                    yes, but if the engine is equipped with a distributor, it is NOT wasted spark. Later B engines are wasted spark, but not those in our cars.
                    Jim DeAngelis
                      And I am curious to find out the difference because I will need to find the ECM to go with this Mitsu dizzy. It came on an unidentified engine. It is a B3, that is all I know...oh it came out of a 1990 mazda 323. However, that is not usual for a car in the states.
                        Should be nice to have a B series with twin spark, like the system used in the Alfa Romeo's
                          good info, my brain is now bigger!
                            I had made some testing for the wasted spark for the b3 but I was wrong. It does not have a wasted spark ignition. I tested how many times the no.1 spark plug fires for every crankshaft turns. It fires once every 2 crankshaft turns = 1 spark for 1 complete cycle. The think that I can't understand is my ignition timing. When I set it to 10deg btdc the engine feels down on power and backfiring many times while decelerating. What can be my cause?
                              your fuel cut is not working properly, and your cylinders are loading up with fuel?
