The b3 engine uses a wasted spark ignition. I had found out. That's why when I try to adjust the ignition timing to 10degrees btdc it always be out of power. The thing was that because it uses a wasted spark system it fires twice for every complete cycle, so the timing light will read always half the timing it's really is. So if I set the light to 10deg btdc, in reality it is 5deg btdc. Anyway, I adjusted to 20deg btdc on the timing light and it is 10deg btdc. Now my question is, can the timing be advanced a little bit more from stock to make more power?
Thank you very much.
