Originally posted by jbeamcoke
Okay, assuming it stopped working all at once, not a gradual loss of reliability, correct? Wondering if you are not having an issue with the safety switch on your tranny. Safety switch is what only allows the car to start if the clutch is engaged. If you look up under your dash, at the back of the clutch pedal, there should be a white box/switch. Push in the clutch pedal by hand and make sure that the little metal plate on the pedal arm is contacting that switch and making it go all the way in. Here's the switch I'm talking about.
That metal ear sticking out in the second pic is what is supposed to push in the switch. Assuming that's working, now pop the hood, and look down at the driver's side of the tranny, down low. You should see two wires going into a plug type thing in the tranny. Follow those wires up near the starter and make sure that they have not become disconnected. IIRC, they go through a white connector before merging into a larger bundle of wires going back through the firewall.
Assuming here that if you turn the key into the "on" but not "start" position, your radio works, that you can turn lights on, etc. Am I correct in assuming that?
