That little black box on the side of the 88 and 89 festivas distributor, is a condenser or capacitor what ever you want to call it. It keeps electrical static down, so things like radios will not have static in them. I do not have one on my 88 festiva , and it runs just fine , been running with out it for a couple of years now.
One thing after another!
That little black box is a radio suppression capacitor. It prevents electrical noise from the distributor interfering with the radio. It's not critical, and will not prevent the engine from running. It can be removed, with the only affect being static on the radio.
It is NOT a ballast resistor, and you will NOT cause any damage by removing it.
It sounds like you either have a weak/dying module (inside the distributor) or weak/dying coil.Jim DeAngelis
kittens give Morbo gas!!
Originally posted by worfdog View PostThat little black box on the side of the 88 and 89 festivas distributor, is a condenser or capacitor what ever you want to call it. It keeps electrical static down, so things like radios will not have static in them. I do not have one on my 88 festiva , and it runs just fine , been running with out it for a couple of years now.
Originally posted by FB71 View PostThat little black box is a radio suppression capacitor. It prevents electrical noise from the distributor interfering with the radio. It's not critical, and will not prevent the engine from running. It can be removed, with the only affect being static on the radio.
It sounds like you either have a weak/dying module (inside the distributor) or weak/dying coil.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Originally posted by doylerl View PostI was wondering if that was the ballast resistor that I have read about. Do these cars not have one? I was worried that I just fried something because i removed it. Any recommendations on a coil that doesn't need a ballast resistor added? I don't want to fry another one of these modules if my coil is too much. Right now, I am using an MSD Blaster II coil on it. Thanks for the help everyone. I have been really down in the dumps over not being able to get this thing up and running.
to answer your first question, no, these cars don't have a ballast resistor. Ballast resistors were used on larger six and eight cylinder cars (typically) to offset the low resistance of the coils used. Low resistance coils (1.0 - 1.5 ohms avg) were used to decrease saturation time, because of the shorter time between ignition pulses (more cylinders = more pulses at same engine speed). Ballast resistors were used to limit current after saturation, to prevent overheating of the coil.
Carbed Festies use a coil with a resistance greater than 1.5 ohms. The higher resistance means the coil draws less current. This is important. The MSD Blaster is 0.8 ohms. It draws TWICE the current of the stock coil. This overheats the driver transistor inside the ignition module. Once overheated, its permanently damaged. You need to replace the module AND coil. If you cannot locate a suitable coil, at a price you are willing pay, you can simply add a 1.0 ohm ballast resistor in series with coil + terminal (between the wire and coil post). This will let you safely run the MSD coil with the stock module. Ballast resistors can be had from auto parts stores, or places like Summit, for a few dollars.Jim DeAngelis
Originally posted by FB71 View PostIf you cannot locate a suitable coil, at a price you are willing pay, you can simply add a 1.0 ohm ballast resistor in series with coil + terminal (between the wire and coil post). This will let you safely run the MSD coil with the stock module. Ballast resistors can be had from auto parts stores, or places like Summit, for a few dollars.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
disconnect all the wires from the + side of the coil. Connect all of them to one side of the resistor (doesn't matter, not polarity conscious). Connect the other side of the resistor to the coil +.Jim DeAngelis
i would imagine that he would need a 1-2.5W resistor for that function. radio shack would probably have to special order something like that though. and as for McAutoParts having a resistor, i havnt seen one in stock in a few years.Trees aren't kind to me...
Originally posted by FB71 View Postdisconnect all the wires from the + side of the coil. Connect all of them to one side of the resistor (doesn't matter, not polarity conscious). Connect the other side of the resistor to the coil +.
edit: The general idea is a 1ohm resistor? Should I go bigger as festyboy suggests, or is the 1ohm sufficient? ThanksLast edited by doylerl; 02-28-2010, 01:22 AM.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
NO!!! He needs a 150-200W resistor!! The Advance down here still stocks the old Mopar resistors. Mallory sells one that's perfect for his needs. Mallory p/n 700.Jim DeAngelis
Use the one I just spec'd. Anything smaller than 100W will overheat and fail. Anything greater than 1.0-1.5 ohm will begin to degrade the firing voltage and spark duration.Jim DeAngelis
that big? the last resistor i saw with that value was a ceramic coil wound tube that was over a foot long and 1.5" in dia. (used for audio amp testing)Trees aren't kind to me...
Originally posted by FestYboy View Postthat big? the last resistor i saw with that value was a ceramic coil wound tube that was over a foot long and 1.5" in dia. (used for audio amp testing)Jim DeAngelis
also remember, there are two types of Wattage ratings;
Continuous and Surge/Peak. An ignition system would be surge/peak.Jim DeAngelis
