Hey guys. Long story short, I had my rear wheel bearings go out on both sides. On the passenger side, the bearing is absolutely stuck on the spindle. I tried using a large puller on the drum and it would only break the drum instead of coming off.
After using PB Blaster and a torch I was still unsuccessful! I decided to remove the whole spindle/brake assembly via the 4 nuts on the back.
Does anyone know where I can get a used spindle/brake assembly?
P.S. Ive purchased new Timken bearings and seals. Also good grease and a grease gun / bearing packer. I'm doing it right this time
2009 Festiva Madness link with pictures. 51 Festivas & 4 Aspires from eight states attended.
