Rear Spindle / Bearings Failed (Again)
  • Rear Spindle / Bearings Failed (Again)
    Hey guys. Long story short, I had my rear wheel bearings go out on both sides. On the passenger side, the bearing is absolutely stuck on the spindle. I tried using a large puller on the drum and it would only break the drum instead of coming off.
    After using PB Blaster and a torch I was still unsuccessful! I decided to remove the whole spindle/brake assembly via the 4 nuts on the back.
    Does anyone know where I can get a used spindle/brake assembly?
    P.S. Ive purchased new Timken bearings and seals. Also good grease and a grease gun / bearing packer. I'm doing it right this time
    1989 Ford Festiva
    Mileage: 152,000
    I would check with tony cash. If not, this would be a good time for an aspire swap.
    My Fleet:
      How much are you tightening the spindle nut?
      91GL BP/F3A with boost
        Good question. Batstiva's failed going down the road at 55 mph and ripped the tire/wheel/half the spindle off because my friends at Midas put an air wrench to it and torqued it as tightly as they could.:roll:
        Not fun at all getting passed by your rear wheel, trust me.
        Packing the grease correctly, and starting out with good quality bearings are important, but overtightening the spindle nut will kill the bearings quickly.
        1988 L - 232K miles Batstiva
        1989 L - 247K miles Slick
          snug it then back it off a 1/4 turn, im sure someone has the exact torque but thats how i do it.
            Think my Hayne's says between 17-20 ft/lbs, while spinning the hub forward, then back off 1/4 turn. Don't have it in front of me right now. Somehow, all 3 ended up in the two festivas.
              Yep, 18-22 Ft/lbs, then back off a 1/4 turn, then tighten it with your fingers until drag 3-7 in/lbs.
              '90 LX
                A small fish scale works great for me in place of a inch pound torque wrench.
                Does a great job of telling what the drag is.
                No problems ever with bearings I have installed..
                Dean
                Festiva Madness Club - Raleigh, NC Chapter
                The wife and I are attending this meet. Come convoy with us.Come to the 1st annual "Sunshine Meet" March 20th 2010. Details in the thread below.
                http://www.fordfestiva.com/forums/sh...292#post295292
                www.festivameets.com
                Festiva Convoy video link [url]http://www.youtube.com/watch?v=VyFYJcFBc_g[/urlhttp://www.youtube.com/watch?v=ANbkG...eature=related
                3rd Annual Festiva Madness. The largest Festiva Meet ever held of owners and their cars 2009 Festiva Madness link with pictures. 51 Festivas & 4 Aspires from eight states attended.
                FM3 short 5 minute clip
                Link to a short 5 minute clip http://www.youtube.com/watch?v=VFyy-zxgV5A
                http://www.fordfestiva.com/forums/sh...ad.php?t=24695
                link to 100s of meets pictures and short video clips.http://s1019.photobucket.com/albums/af316/festivameets/
                4th Annual Festiva Madness meet will be held Oct 2, 2010 in Raleigh, NC
                Cell is 919-271-5190 deanraleighnc@cs.com
                  Thanks for the reply guys. I'm pretty sure I tightened the spindle nuts too tight causing friction and eventually failure. Also the grease was kind of old an may have some grit in it. I got new Timkens, good grease, and a bearing packer now. Just need a new brake/spindle assembly. The funny thing is, I just had Tony Cash send me a spindle for the same side Hopefully hes got more...
                  I don't have a torque wrench so is 'hand tight' good enough? And whats the best way to secure that nut on the spindle? Just notch it with a punch? Or is there a special tool?
                  1989 Ford Festiva
                  Mileage: 152,000
                    Autozone has torque wrenchs you can rent for free.
                    '90 LX
                      i did one thing that probably some have done after doing the torque specs i drilled a hole and put a counter pin in i had my tire on my ford windstar pass right by me so i did this and noticed its simular so i did the same thing to the festiva
                        I got a spindle from tony cash that had a hole pre-drilled in it. I was surprised to see that. But it makes sense to do that. My wheel was soo close to coming off its scary!
                        1989 Ford Festiva
                        Mileage: 152,000
                          UPDATE: I put the drum on a vice with a lot of heat and a big hammer. I was able to save everything but the drum. So once I get that, I should be good to go.
                          I also borrowed a in-pound torque wrench from a friend.
                          Wish me luck!
                          1989 Ford Festiva
                          Mileage: 152,000
                            Good Luck, hope you can get it rolling again.
                            '90 LX
                              Wybnrml,
                              So you are sure that its 7 inch pounds? I converted 18 ft lbs to inch pounds and it says 216 inch pounds? I'm confused...
                              1989 Ford Festiva
                              Mileage: 152,000
