I was using a friends E-350 van to haul some stuff I had to get from Home Depot and on the way home I noticed a pretty bad banging noise coming from the engine compartment....I didn't notice it when I was driving cause it's kind of loud....a quick look at the temp gauge and it was going up pretty fast. Just before it topped out, the banging stopped and the temp gauge went back to where it normally is...I'm thinking a bad thermostat? I've just never heard such banging coming from and engine compartment, sounded like someone was going crazy in there with a gold club....is that the pressure trying to get out or something?
Banging in engine compartment?
any signs of leaking? check the pulleys for play as well...Trees aren't kind to me...
You need to feed the racoons under the hood they are hungry
Seriously though check the idler puller econolines are notorious for that - and while you got the belt off check for play in the water pump - that may be your banging
I can't tell you how many econoline box vans we used to get in that had temp issues - what was happening is the idler pulley was failing causing added strain on the water pump making the bearing go out in the pump.
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
How bout the fan, electric or not, banging against the shroud?Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Open the hood, take the club away from the guy......Originally posted by The_Collector View PostI've just never heard such banging coming from and engine compartment, sounded like someone was going crazy in there with a gold club....is that the pressure trying to get out or something?Dan
